Sold / Found Milling Machine 3 Axis
Status
Not open for further replies.
CraigRobbo
Salford, Manchester, UK
HI.
On the bed & cross slide the pics have made it look rusty due to the flash but its just grease from maintaince thats all.
Now i am unsure of its brand but it REALLY looks like the axminster one.
I checked out the same types on ebay and 2 went for £641 and £653...
Similar sized machine by other brands for for very similar prices & some closer to £700
I would take £500 if you came to colellect which i think makes it a pretty good deal.
I will even (because i'm nice like that) give you a few starter milling bits too of different kinds to get you going.
I have some T-Bolts and what not for it too.
Over all condition is very good, a little paint scuff here & there but to be expected, however all mechanical and working aspects are 110% perfect & the bed hasn't got a single mark on it.
Some specs taken from the side of the machine.
  • Milling/Drilling capacity 16mm
  • Speed Range 200-2740RPM
  • Column Diameter 70mmm
  • Spindle travel 80mm
  • Workable Surface 420x152 (this can actually be made bigger by using a surface plate which is what i do for larger pieces)
Status
