mix 2stroke with nitro?
kryptonite5b
philipsburg pa.
ok, so i have your attention.. this isnt the dumbest thing i have ever posted, but pretty close. mind you. i am not sugjesting anyone try it, or am i going to try it. but im wondering if any one else has had this "not so bright" idea and what were the resoult. im just wondering what would happen(besides the carnage). would it even mix with the fuel, or would it seperate? would a couple ounces in the fuel do anything? im thinking that if it was simply a power booster someone would have cought on by now. just a miday thought..:helpsmilie:
intresting.
i think nitro is totally pointless on a largescale engine nitro it self does nothing its the extra air (oxygen)that creates the power.
the reason nitro is of use in the small nitro scale engines is because of there size,did you ever see a proper two stroke in that size,no!
size is the answer,the small engine is just suitable for the glow nitro fuel.
as for our engines you mite aswell be pis###g in to them to get them to run faster.#
of no advantage.
plus advantage of our two stroke set up is cheaper fuel prices...
i think gas engines are powerfull as they can be without nitro,its just think people forget the benefits of gas over nitro.
anyway i don't think nitro would do anything for this engine at all,carb wouldnt even work properly i think.
put it like this anything with nitro needs very high rpm,yes running nitro with your engine may increse some power if you got the ideal mix,but at what cost,prob blow the engine to bits.....
our largescale engines are designed to run low rpm to retain resonable reliablity.
the link below is good at explainin your engine in theory and nitro set ups.
check out this link.
http://www.rchelicopterfun.com/model-gas-engines.html
this is an intresting link also but has nothing to do with nitro lol
http://www.houseofdreams.ws/amsoil/Two-cycle Engine Applications.htm
ya, i don't know all those diffrent components of the fuels, but i just saw some alcohol conversion and was just wondering if the 2 could mix. as stated, i wouldnt try something like this, but i thought there might be some other non-informed folks that would have thought about it. and by those links, i was right..
