Modified Bodywork XSC Air Intake . New Decals layered
TIROD KERRY
Ft Worth Texas
Here is my XSC I cut a hole in the rear and placed a Air intake its functional right above the muffler . I was hoping it would look good on the roof, but that did not pan out . The plan was to let the air in and blow away all the grass and dirt that stacks up in there . And of course The layered decals of real flames and skulls . And a superbee kill switch man that thing works great . Enjoy
Yo TIROD I see you relocated the body post's to mount to a lower area more prone to damage due to roll-overs. My Q is how well are they holding up?P.S. the scoop looks sweet
The body post are still there under the scoop with no pins in them . sence the scoop is in the way, and I did not want to cut into the scoop to get to the old body post , I made some new ones . I made new holes at the back of the body and got some larger pins to place there . At the bottom of those new pins under the body they are tied to some very strong string and the string is tied off to the middle shock tower . The pins draw pretty tight pulling the body down . So far its worked like a charm . If the body comes off it will still be hooked up Ill just need shorten the string till i get it just right and the body should stay on if it rolls over . But for sure will stay on over jumps . The pins move around and have lots of give .post pins.webp
/monthly_2012_09/583c60652bc40_postpins.jpg.c8db7ca2061d74ce08639035f6692918.jpg
