Modifying A DDM Torque Pipe question.
KauseKaos
BKLYN, I'm Home...
After some thinking and looking at the DDM pipes i started to wonder. How would it affect the performance of the pipe if I was to cut the curve out and have the pipe re-welded to come straight back. Main reason for doing this is to save my next Marder Beetle bodies from being hacked to hell. I was gonna sell it but i'd figure try it and if it doesn't work i'll just go ahead and buy another pipe like i was planning. Below are the pics of it. The last two is where i'm thinking about cutting.
In boating the length from the sparkplug to the widest part of the pipe determines the torque and/or the top end revs. The longer the pipe the more torque and the shorter the pipe the more revs the engine makes.
typically the wide area of a pipe is for torque. the longer and thinner the pipe the more top rpm. pipe length (espcially the belly section ) really determines the lenght of time the power is On so to speak.
so you can drastcially change the performance by changing the pipes length.
I would try it.:) Can't make it worse then a stock pipe. And it wont be as bad as the HPi pipe. You may surprise yourself. I think many could speculate on the final product but until the prototype is designed no one will know the true performance. Who knows you may create a new style DDM pipe.
I would say I think it would be better then the FG I have due to its cone shape.
