mods list for everyone
kryptonite5b
philipsburg pa.
so lets take a list of some of the mods or upgrades we have on our rigs. this would be a good referance for our newcomers as to what "most" of us are doing. wether its a DIY mod or an aftermarket. whatever makes our rampage better,faster, or stronger. also feel free to put in some things you tried and DIDNT work.
my rig is still fairly new, so my list is short.
-upgraded diffs-3,000wt ofna diff oil, not sure how thats gona work
-longer shock springs,
-60wt,back, 50wt,front
-upgraded gear plate
-upgraded fuel tank vent
-front and rear lower aluminum arms
-aluminum stearing mount
-gutted stock can and removed stinger
-8000rpm clutch spring
-813 "punch" carb
-lowered mt body mounts for less damage,shoe goo'd body corners
-centered all drive shafts using foam earplugs
-DIY pullstart cover, and spun pull starter so can start with body on
-scanner rc steering and brake servo w/Y splice to steering servo,(st)320oz@6 volts,(th)200oz@4 volts
-futaba 3pm
-longer brake spring
-fast eddy bearing, not all
i will edit as parts come in..
Great post idea Krypto I will have to get back to you my list is quite lengthy and some is top secret because of new product development , But will do what I can to help this post. Maybe someone else get some good ideas.
26cc fuelie, hpi rims w/ Hostile mini mx mediums on all 4 corners RDlogics pipe ( sprint modded header), cv shafts (untested as yet) gbe axle extenders, aluminum gear plate, steel 25t gears, 20% stiffer springs, as of right now. This is one of those lists that keeps on growing
1. aluminum gear plate
2. phatdad sockshafts
3. ramtech 20% springs
4. o-rings in diff cups
5. 28.5cc DDM race ported
6. stuffed race crank
7. JetPro tomour pipe
8. Front A&B aluminum
9. Rear uprites aluminum
10. all sealed bearings from my stock
11. HBZ roll cage hoop
12. many custom mods
13. 813 carb
14. ACE 1015 for t/b
15. 5745 steering
16. HPI air filter
17. MCD gears
18. UPGRADE kit worth every penny
Think that is it for now, sprint pipe as soon as he has one ready to go to Canada.
shock limmit straps and duel steering servo setup with a new battery box to fit over 2nd servo like that one rampage mt pic with all hopups on it that don't have a parts list for those parts
I think listing like Clubin is the way to go, but let's go one step further. a list of must have options first
Then a list of things you might also want to consider
Truck is basically stock right now except for a gutted can with a 5" long flare-cut stinger. I painted the gear cover and windows black for aesthetics. Mods on their way from Rampagehopups include:1. Upgrade kit2. DarkSoul wheelnuts3. Aluminum gear plate (blue)4. MCD 27/33T gears 5. MCD 25T gears (plastic for now)6. 36mm 28.5cc GP290 Big-Bore KitAnd my last project.
/monthly_2009_02/0131092030.jpg.6ae32b627820394d393750cf5e2913de.jpg
/monthly_2009_02/0131092031.jpg.9061389b14bd6d2aaf31732dd023c4cb.jpg
/monthly_2009_02/0131092033.jpg.b7a428bafb2f1239f09b678e22b06bd3.jpg
/monthly_2009_02/0131092032.jpg.061455f9b4860a066d9207eda112619f.jpg
/monthly_2009_02/MAG57.jpg.3fa36d0d74d87a0d1c3d557ac9f56a10.jpg
