MOfroggy
I would like to know if anyone has come up with a modification for charging the battery externally. I guess you could use a Baja battery and modify the case to hold the charging jack.
I also would like to know about a modification to get the antenna off of the top of the receiver/battery box. Having it up there and running through the top seems like it is going to be a problem. The antenna outlet is on the inside of the roll cage and top of the box has to be manipulated to get anything out of the box and I am afraid I am going to eventually either break the antenna wire or stretch it down into the antenna tube.
An easier way to get the receiver/battery box off would be good too. There are two different sized screws in mine and a total of 4 screws. If you have to take out all of these screws to charge the battery that could get to be a real pain.
Any suggestions?
MOfroggy
Any suggestions?
MOfroggy
