Trip
Ever since I put my Jet-Pro pipe on this thing,(M/T) I can't get it to steer worth a damn. If I am on the throttle, in a paved parking lot it takes about 100ft diameter to make a complete circle! It just pushes like crazy. If I let off the gas it steers just fine. If I am in a baseball diamond... Forget it, go in a straight line, hammer the brakes and then spin it around. I can't run the bases on a little-league field. Steering is excellent in the grass though.
I am running a Hitec 5745 and it easily turns lock to lock whether it is on the ground or up in the air.
The rear diff is open (not locked) and just filled with grease, no silly putty. I do have front cable brakes but it did the same before I put them on.
It only does this when I am on the throttle, now I don't mean when I a pulling a wheelie, of course, just building a little speed.
Front toe and caster is stock and camber is non-adjustable. Everything but the brakes, pipe and motor are stock (including the shocks and shock oil) rear sway bar has been removed.
Is there anything I can do to improve my steering?
Thanks guys,
Trip..
Thanks guys,
Trip..
