Mother F@#%&r!!!!!!!
yep I'll be @ work, I'll bring it by ....btw I've only done the rears, my fronts haven't gone yet :) ... I decided to put rear shocks In the front so I need to order those tonight..
The truck will hit the ground before the shock bottoms out with that setup... Once I saw my rear did that, I checked the front... Nope the shocks bottom out and the truck is still 1/2 of the ground... That's when I decided to do the rears in the front
The droop is garbage.... Just maxed out my adjustments and it was fine... Not stiff and not to much sag.... I put 35 wt oil, I love my suspension to be smooth, it worked ;)
That's with ramtech springs
kryptonite said:
check out my thread on the suspension set-up. sounds like your running on all spring their.. you'l notice a huge diffrence once it set-up good.
1,200 threads and 12,000 posts......you're gonna have to give me a clue! I know, I know......I found it but a link is priceless sometimes.
