motor temperature
kbreaux100
pueblo colorado
i think i may be running a little hot. i cant find information on the heat range of these motors.does anyone know what the heat range is and the best place to take a temperature reading? also, are these motors like nitros? can you use your temp readings to evaluate your tuning?
most tuning is done with ear,performance and plug color! Most temp sensitive is during break in and heat cycles during head torquing.
i don't think so.im at 1 1/8 on the low and 1 3/8 on the high.im at 4800 ft. above sea level,and from what i hear the thinner air makes you run richer,so i shouldnt be lean
Looking at the plug, light brown to tan colored insulator. Using the TQi temp sensor positioned just above the exhaust port, I've found that a reading around 280 degrees gives that lean condition. I don't run really lean, just close to peak.
good to know about the 280. ive also put red locktte on my exhaust screws cuz they keep rattling out and the locktite is rated for 320f.didnt know if it would hold at the engine temps,but i think i should be good knowing that a lean motor is only 280
Ive wondered about the temps as well. Im by no means lean, and i do know how to tune. My issue lies with setting up my temp alarm on my telemety radio. What would be a good temp to set the temp alarm at? Im running a different engine tho so i freak out when it gets to 170 lol. Figure now i know ill be more than safe if i set it to 200.
Are you using a torque wrench on the exhaust header screws. Torque is 65 in/lbs. Shouldn't need Loctite.
I need to change the screws for my VRC pipe. Both are hex head, and with the bend of the header the only way to tighten the right screw is to use Vice grips. Can't get the needed torque, and get exhaust leaks there. Need to go to a bolt.
no i haven't used a torque wrench,but the red locktite is seaming to hold up fine.i went out today and took readings at the exhaust xport on my x can,and it was in the 350f range.this seams extremely high but im running rich! maybe the exhaust gets hotter than the actual engine? i hope so cuz that temp is scaring me.i tried to even run about a 16th richer on my low but it didnt help.i am wondering if something is wrong with my engine.i checked for air leaks so i know that isnt it,ive checked plug and it is a medium light brown,and the engine seams to run great
