jeeper049687
I've had a friend of mine tell me that this is impossible that the XT plate is much thinner and smaller than the MT. I've been staring and pictures of both the aluminum XT hopup gear plate that uses the normal XT size bearings; 'kinda small" and the MT blue plate, that has much bigger bearings, which is better. Now it seems like all the mount holes are in the same place for mounting and the shaft holes/ bearing holes are also the same location, just need the bigger bearings. his agrument is that there is an aluminum gear plate make for the xt so theres a good reason why that is, "because the MT does not fit!". If this is true and it doesn't fit im open to some modifications to make it fit btw. im not afraid of some cutting, drilling and welding. i'd make my own plate out of a chunk of aluminum, but i don't have a milling machine on hand, and the local college machine shops don't open untill september, and im not waiting that long. Just asking you guys cuz i know you'll know.
