I agree some proline rubber. A nice pipe makes a world of difference !Guantanamo Joe said:You don't want the XT wheels and tires... that is a pretty large step down in quality. I have an XT, the foams are not good. The rubber is glued to the rim. Get yourself some HPI adapters and run some good pro line tires and wheels. This will shave about 10 lbs Then, it will add a little weight, but invest in a good pipe and you will be BLOWN away with what that truck will do.
(or just get the pipe and keep your stock tires- you will absolutely love the fun you can have when the pipe wakes that beautiful stock engine up!!!!!!!!!!!!!!!!!!!!)![]()
The plastic is the same way. I like a combo of plastic and aluminum parts. The plastic breaks but the aluminum bends. Both can fail in a bad wreck.Tangermean said:I was hoping going back to the plastic parts would make the suspension a little tighter. There is a decent amount of play between the C-hubs and the Upper/Lower arms.
