MT PRo won't roll forward
chadj1980
I bought a used mt pro and since the day I got it won't roll forward if you try and push it.. Backwards no problem.. Any ideas would be greatly appreciated.. Running under engine power goes fine..
It actually is a engine clearance issue I believe.... It appears with my engine bolted down everything is crooked and if I take bolts out the bottom it is beautiful... also engine has been hitting the rear shaft a little.. Know what do i do.... Spacers under the motor??? zenoah motor..
I had both front and rear diffs appart, When i installed them back in I rolled it forward and it had a small issue. I found I put the diff gears in backwards in the front diff :/ Easy to do.
I got it all fixed it was that previous owner didnt have the engine spacers under the engine and it was binding in the clutch bell..Its all fixed now..
