MT tires back on. need advise
brad1161
I had been running HPI rears on all 4 corners. No issues with drive line. Wanted to change it up so i put MT tires back on. Any new upgrades to save my diff cups?
Also I put the lowest gearing on possible.. the front side gear was rubbing cover. Dremilled the cover a bit.. Now my gearing is lower than factory. Im not looking for speed. I have a baja for that.
i had dunerunner gear kit also. maybe thats why the last gear was a hair to large for side gear covercover
BertR said:
You must be running 25,35,24,26 ... The 26 as your D gear is a tad to big for the cover.
Yep. A little sanding and it fit good. Little lower gearing
