Deluge1
Those fittings don't quite fit in the grommet, they're a little loose. When you install them, put a piece of fuel line on the neck of the fitting. This will give them a better fit and a tighter seal.
Just driving it.Any updates on this great looking truck?
That reed case should fit a XB right?RCDAD said:Yes and yes.It still needs the 8.2 hp OBR reed case.![]()
WOW... is that some sort of shielded fuel line? I like it.... or is it just for look? A filter on the fuel line huh? Where can I get all that and is it worth it?RCDAD said:For the other side I added some braid for the fuel lines with filter and a blue double sided choke lever all from python. Not to get off the subject but has every one seen the delivery chick at the bottem of the python purchase / shipping page. I keep looking for her when the parts come. I painted the center of the gears just to dress them up. I was hoping the pretty gears would make me happy until demon releases the belt drive and two speed. It didn't work I still really want both from demon. I also had to get the aluminum fuel tank cap from nitro rc.
Just for show. I've since taken it all off...WOW... is that some sort of shielded fuel line? I like it.... or is it just for look? A filter on the fuel line huh? Where can I get all that and is it worth it?
Yes, It should fit fine.That reed case should fit a XB right?
Why is that?RCDAD said:Just for show. I've since taken it all off...
Might have to upgrade all my bearings just for the new engineRCDAD said:Yes, It should fit fine.
I thought it looked a little sloppy. The braid did not stay tight on the line. I like the look of the colored transparent line better.Why is that?
