MT V1 to V3
NUNCHUCKSKILZ
West Des Moines
So I'm looking for some info on converting a V1 MT to a V3. I know the Chassis and the Diff Cases need to be swaped. What other parts are needed.
Do the V1 diffs fit in the the V3 Diff Cases?
Does the V3 chassis allow for the V1 single servo set-up to mounted to it?
Any help would be apperciated.. Thanks Guys
I found out the part number for V3 front lower suspension arm is 50004N, they come as a set, left and right. Rear lower suspension arms are the same deal I think, didn't order those. All the shocks are different, with a 1mm heavier rod, I think the shock towers are different. All the wheel bearings (50069, 22X10X7 mm) are the same.
I also found out going by the part numbers on the sheet that came with the V3 Dune Runner you need to really check when you get online, and make sure that is the correct part number. For example: The sheet lists the front lower suspension arm as 50004, which is V1/2.
So from around 2 hours yesterday ordering the front lower suspension arms, wheel bearings, some screws and e-clips and making sure I was getting the correct parts, the difference with the V3 appears to be the diff cases, heavier duty suspension parts and shocks. And the HY 30.5cc engine. Which isn't listed on the sheet at all.
