Sold / Found Multiplex Power Speed Servo
Status
Not open for further replies.
tizdaz
Sunny Northwest!
Multiplex Power Speed Servo with rubber fixing grommets as seen in pics
Good condition & Perfect working order
An excellent Throttle/Brake servo for large scale models such as HPI/FG/MCD etc
The Multiplex Power Speed servo was created for the 1/5 and 1/4 scale car market. The Power Speed features a robust gear train, super strong output shaft to give you the durability and performance you would expect from a Multiplex servo. This servo is best suited for use with Throttle/Brake on Largescale models
Modulation: Digital
Torque:
4.8V: 85.0 oz-in (6.12 kg-cm)
6.0V: 106.0 oz-in (7.63 kg-cm)
Speed:
4.8V: 0.29 sec/60°
6.0V: 0.24 sec/60°
Dimensions:
Length: 1.85 in (47.0 mm)
Width: 0.91 in (23.1 mm)
Height: 1.85 in (47.0 mm)
Weight: 2.89 oz (81.9 g)
Will also throw in an alloy double servo horn
£32 posted (UK Only due to postage)
Status
