- Manitoba
What upgrades have you done to your FG? Just curious.
Tuned pipe
V Stack, Unifilter and Outerwears
Steel gears
Alloy gear carrier
A & B front alloy mounts
Alloy radio tray
Front cable brakes
Alloy engine mounts
Alloy diff upgrade
Elcon S/S diff cover
Daniels Pitstop rear alloy lower arms
Also have but not fitted yet - Elcon drivetrain
In actuality the upper rear A arms have been replaced for years due to them being a weak point and snapping at the area the rod enters them. At some point someone started saying they stop flex in the rear and forgot the real reason. I too went under that assumption and bought a set for the flex problem. After investigating old postings and a little investigation myself I found that the plastic ones were weak and could snap at the rod entrance and did nothing for the flex of the rear.You could go a set of alloy upper rear arms to stop them from flexing and ripping teeth from your spur.
