Harold Bascom
I'm having a ton of fun putting my new Rovan Baja 5b back together after taking it apart to understand how it comes together. In the process, I discovered that as far as Rovan is apparently concerned, the usual complaint of clones coming apart, nut by nut, screw by screw, and bolt by bolt, would not easily apply to their clones. Lol. It seems that red Locktite was used on everything in the buggy I got. In trying to loosen bolts, most gave me a fight. One head stripped so badly, I had to dremel a groove to used a screwdriver.
My plan is to invest in a little butane torch with which to heat up bolts and screws locked too tightly.
All in all, I'm having a good time. Some of the upgrades I've made thus far, is installed a push/pull steering system. I also reconfigured the top of the cage (the roof) and made it so that I can flip a section up to have easy access to the spark plug. (See pictures.)
