haha thanks. I'll loosen the screw that you're showing when i get home.Ice_2k said:Nevermind, I found one of mine:The part underneath the servo arm, which holds the throttle linkage, needs to rotate as the servo arm moves. If you screw that in too tight, it will be forced by the servo to rotate when braking (servo rotating clockwise in the attached image) and, when returning, it will not rotate back to the neutral position, and it will grab against the throttle linkage, pushing it. After 1-2 seconds, the carburetor spring slightly pushes it back to the neutral position and so the throttle is disengaged.
hahaIce_2k said:Since you say you can turn the wheels by adjusting the steering middle position or with the throttle when reversing channels, I'm guessing it's your transmitter that's faulty. Probably the control wheel.... sorry, no magic solution this time![]()
that one's like 180! almost half the price i paid for the Chimera lolIce_2k said:I upgraded to the Flysky FS-IT4 because I wanted telemetry, it's an awesome unit
thanks for the recommendation, but that's still a 100 dollar controller. I'm trying to stick to the 30 dollar range. i've found 3 that i've posted links to. which of those 3 would you think is the best out of the 3?RampageHopUps said:Go for the Futaba 2PL if you are on a budget.
lol buddy, i pull in 160k a year and am worth 7 figures. i can afford the extra 70 bucks, i just choose not to spend the extra money.RampageHopUps said:Well the stock Redcat is a sub $30 Flysky controller. So I would work some overtime or eat PB&J and get a Futaba.
I've been using Futaba for over 30 yrsRampageHopUps said:Well the stock Redcat is a sub $30 Flysky controller. So I would work some overtime or eat PB&J and get a Futaba.
Actually just 130Chimera said:that one's like 180! almost half the price i paid for the Chimera lol
