G
Guest
Guest
Awesome news man!
That certainly would be pretty sweet. And it would be nice to have some brakes you could actually use to have a racing advantage too. But, I need to keep this thing as simple as possible. Right now in 1/5 racing, if you just finish the 30 minute main you're way ahead of the pack.Ildy666 said:Did u think about 4 wheel disc brakes like the 5th road cars.just a suggestion...
Thats like any racing.finishing is half the battle.i raced motocross 20+ years ago same deal.prep the bike and hope everything u did.pays off....mulepic said:That certainly would be pretty sweet. And it would be nice to have some brakes you could actually use to have a racing advantage too. But, I need to keep this thing as simple as possible. Right now in 1/5 racing, if you just finish the 30 minute main you're way ahead of the pack.
Direct drive certainly simplifies things. But as you read, I needed a low current setup so I could compete in 30 minute races. Good luck and keep us posted. Do you already have a build thread?Shiny said:Just finished reading the thread . I started 3 dates ago.Amazing what you did hear. I was actually concurring the DR for brushless conversion. Actually it's shorter brother from HSP. But what I want is direct drive no clutch involved and sort of FG HPI small pinion and big spure approach or the Titan/Gas Devil/C5/Thunder Bolt 2 big gears.
Hope all go will.
Just an ida since you are handy withe machining, if you reposition the middle diff to the canter the shaft will be straight that should stop the wear. You will need a shorter shafts thou.mulepic said:Here's what I'm dealing w/:![]()
How much longer can they last and what are the part numbers to replace them?
