- Thread starter
- #81
Thanks guys! Although I do have a concern again, I took off my fan cover and shroud today to clean out the grass that had been accumulating in the fan area and noticed that a lot of fuel/oil had been leaking from the head gasket.. so much so that it looked like it had dripped right on to the flywheel while running and it shot oil all over the side of the cylinder and ignition coil. It has leaked around the entire head. I checked the bolts with the torque wrench and they are set right to spec. It's likely been leaking since I first ran the engine, but I just noticed it now. Just when I thought everything was going good lol
Going to have to break it down again and put a new gasket on, might try a copper one with a spray on sealant and hope for the best. Haven't had any luck with the head gaskets on these 2-bolts
This one was a heavy duty steel reinforced.
