my new dunerunner
loganvass
maine
Hi guys.I just boutgh a dunerunner and cant wait to play with.that is my first rc car ever and i know ill break something.
Do you guys recomend any upgrade i need rigth way?or maybe i should change when i break it.
Can a transmiter from other car works on dune? I saw specktrum dx3s on ebay,but was for losi.
Thanks .
Edson
I own a DuneRunner too :)
make sure you check all the screws/bolts and such before you run it..
yes a dx3s will work.
What size is your engine,seems like everybody have a 30cc,i could'nt find a dune runner 30cc for sale.do you think i shoud try find one?
DuneRunners come with a 26cc.
you can buy a 30cc engine or rebuild the 26cc yourself with kits...
chevy said:
I don't think your dunrunner needs a 30cc thats overdoing it, go with a 26cc get higher rpms
How can i do that?
Can you please make a list what do you think should i upgrade right way.
Can you put the same size back tires in the front too?
Well, first it should of came with a HY26cc so just add a pipe to that. and adjust the needles to a better pickup and still smoke...(rich)
hpi 5b/5t pipe works well and cheap for starters..(check my vid for it's sound and small grunt..lol)
unless one of the exhaust engineer's through this forum have one for a Dunerunner..
that be neat :)
change that gearing to fit your needs after that..
order back tires/foam, so you can change over the rubber..you will burn them up quick..lol
and remember thought/rule,
check over the drive system
pull the dogbones and check to make sure the pins are not loose
it's kinda of a pain on the first time doing this but easier the next time.
as with all RC items ,you need to check over all/most of the screws
both my diff's were full when i pulled them...which is a good thing.
have fun...
just got my dunerunner yesterday and already lost a dog bone pin (4x4 quickly became front wheel drive 2x4) so yea i would double check 'em all just as lords said to do
Hi Jimmy B here!
I have a Dune runner and it took me a while to work out the bugs
1,Check all screws and use red lock tight on the dogbones
2. change to metal gears I ground my plastic gears the first day.
3.I had problems with the stearing servo so keep www.redcatracing.com
on the friends list to order parts and they will replace all eletronic parts for free
minus the shipping to redcat.
I have a 30.5cc ported and domanator fast pipe
it realy makes it fun.
Good Luck!!
http://www.redcatrampageforum.com/picture.php?albumid=129&pictureid=989
hey bolej65 how do you change out those plastic gears i couldnt seem to remove them before and also where did you order your new metal ones from ??
