My Project a used Rampage MT
Cajun
Lewisville, Texas
I took a few shot got it apart going through all key parts, Since my controller died on me while running for a good 2 tanks. Going to redo wheel bearings and switch steering servo. learn all the bolts and make sure they have locktight, got to buy a transmitter this weekend so while it is down I am fixing goodies, cleaned and spray painted the gear cover and the pull Starter casing on motor everything else seems pretty solid.
One thing I noticed my brother in law removed the front wheel drive so I will need to hook that up and make sure it is not connected because it is broken.
Any other things that I can check or replace that are cheap that will
Video of Front hub screw missing from front
Cajun said:
I took a few shot got it apart going through all key parts, Since my controller died on me while running for a good 2 tanks. Going to redo wheel bearings and switch steering servo. learn all the bolts and make sure they have locktight, got to buy a transmitter this weekend so while it is down I am fixing goodies, cleaned and spray painted the gear cover and the pull Starter casing on motor everything else seems pretty solid.One thing I noticed my brother in law removed the front wheel drive so I will need to hook that up and make sure it is not connected because it is broken.
whats poking out on that body?
I have no clue if it is the MT or XT the Book had it marked as a Monster Truck, it has got the 30cc motor.
that is what I am guessing he had the exhaust running before, it has got a that Nice loud Orange Hooker on it now so I was thinking about cutting some holes in the back so the exhaust can get out from under the body.
I am heading to Mike Hobby shop in Dallas to let them take a peek at it and see if I am missing anything that needs to be replaced or fixed. The video shows a bolt missing out of the front hub so it is loose as all get out
I also have one of these in a bag 50012 Servo saver, along with another set of shocks. I need to look and see if it already has this on there and if not should I place it on there
Well sure enough after getting off early because my pull start came in I took it out for a quick run around and guess what came loose the orange X-Can lol the 2 bolts inside, so had to remove the 6 bolts on the outside to get to those 2 lol, Hello Locktight
