metal finisher
check out my build in my album
You can get a TORX bit that fits right into a damaged 3mm hex head if you pound it in with a hammer. Then, use a ratcheting screwdriver to unscrew the bolt. If the bolt has locktite make sure to heat it up to loosen the locktite. I've used that same dam TORX bit for years for stripped 3mm heads in all my cars. It's one of my most valuable tools. I'd suggest everybody go get one.jackson said:i wish i could be sharing a good experience but as of now am almost trowing my rampage out the window all of the screws are stock and they wont come out one by one they're making me angry to a point wich i canot do anything to it dam screws just decided not to come out so please some one give some light before i end up destroing what's left of it!
becouse of one dam screw i have to taje the whole truck appart and that's becoming a nightmare so guys please any advice on it? o by the way the screw heads are no longer of any fit what'so everam afraid i'll have to drill every one of them!
