my rampage mt monster truck issues
dalentx
Junior Member
ok i did have probs getting my truck started...but i finally got it going an been running it...but now while im running it an its not out of my range...it will just up an stop...it stays running but it stops an i pull the throttle an it wont go...i have to walk towards it a little bit an it will go again...why is the truck doing this or what causes this issue
Sounds like a radio issue. Check all batteries and conections to the reciever in the truck. Check your antenna for kinks or any out of the normal.
the antenna is just a little stub..it doesn't retract in an out...i put new batteries in it...my connections are good
What radio/RX are you using? I found that the stock radio system is hit or miss. I have had one work correctly then the another had range issues. I saw a video that went over a fix with the transmitter's antenna but I switched over to my Futaba system and had no issues since the swap.
