My Rampage XB project
designed2survive said:
And pheerider here the center overhead view you asked for.
Alright let me open that box from DDM now.
wow roomy , pipe looks tidy def have to trim something considering the body maybe wrap it, its a great match with chassis no doubt. wing is deluxe man, huge !
Thanks pheerider! Yeah it's very tight around the pipe. I have decided to move the engine and center diff maybe 1 to 1.5cm to the right side so to create room on the left for the pipe. I will have to flip the steering servo too and figure out what I'm doing with the throttle servo. Luckily it's doable
rcgasser said:
Looking very nice looks like it built like a tank you should have no problems bashing the heck out that.
Thanks, rcgasser!
Maybe try a MT pipe from jetpro the bleed is on top.might fit better.
.... but project looks awesome nice clean job on fabing stuff up.also quick turn around no feet draggin....
definitely got options plenty space, maybe flip the tank, flip the pipe shorten the header /pipe at connector to get the position u want, rather than redrill chassis.
totally would hack pipe before retap bottom
Ildy666 said:
Maybe try a MT pipe from jetpro the bleed is on top.might fit better..... but project looks awesome nice clean job on fabing stuff up.also quick turn around no feet draggin....
Thanks Ildy666!
The problem with the MT jetpro is that it's even further away from the engine starter.
Yeah trying to get it done so I can actually start the engine and test drive to see how it goes.
phreerider said:
definitely got options plenty space, maybe flip the tank, flip the pipe shorten the header /pipe at connector to get the position u want, rather than redrill chassis. totally would hack pipe before retap bottom
It would be ideal, but unfortunately I don't have a welder and don't know anyone with one.
Problem solved (theoretically). I'm moving the whole center drivetrain including the engine and gas tank 20mm to the right.
way to do it man. definitely saw that coming . lotta work dude!
dogbone float still within limits ?
looks perfect , tuff to swallow when you first realize it i have done it countless times myself.
the re-balance alone will make this unit a supreme driver with amazing stability.
phreerider said:
way to do it man. definitely saw that coming . lotta work dude! dogbone float still within limits ?
The dogbone pins once centered will be in the middle of the groove in each cups. Is that within limits?
Yeah, at first it's like oh boy now what? Lol!
That would be cool!
Thanks pheerider!
With things being moved to the right, I have 2 options. Move the steering servo to a new location or create servo mounts to place it upright and sideway in the old location. I think I'll mount it upright. We'll see.
