My Redcat Rampage with a new motor
1983bobby
Active Member
2006 model Chung Yang CY29RC headkit engine (35mm bore, 30mm stroke - 28.9cc) with Walbro WT-668 carburetor. The 2006 model features a red spark plug cap, a rubber kill switch cover, improved cylinder plating, and a high-polish finish on the billet head! Includes 54mm inner clutch assembly pre-installed. Includes choice of spiral billet head shell with 14:1 compression dome. Ready to bolt-on. 3.75 horsepower. Similar design to the Zenoah G230RC/G260RC - 4 transfer port hp cylinder, single ring piston, double sided finned flywheel, etc
Love the motor over the stock motor have the same motor in another truck I have for two years no problem with it except for when I pull the pullstarter cutting my finger from the motor having so much torque I quick revs because I love that sound the pipe got off ebay for about $60 and had welding shop cut and weld to size for $10
I see... my XB looks a bit like yours. Just less aluminum, mine is pulley and a different motor :D
[ame]
[/ame]
