my shock is leaking??
CSR260
LiVeRpO0L uK :P
What do i need? parts ect? for rebuild coz i filled the shock up three
days ago and the is no oil left in the shock :blink:
cheers
inside the piston there is about 2 clear O-rings you can add another clear O-ring totalling 3. Its going to be hard to install the circlip , what you can do is just push the brass ring with a 5mm allen screw head till you push to get the circlip in place. I have been using this method and so far no leaks. Give it a try......
No its not bent but its leaks alot! so it will be just a seal then? oh and do I get stock seals ur is there beta ones out there?
Cheers
Normally find them listed as 'silicone' O-ring seals - I'm sure Timmahh or Pipeous, Trebor, Super, BtB have other ideas.
You will probably find once you have your replacement O-rings the one(s) you remove will be quite hard - this inflexibility is why they leak, else they may also have been snagged.
