speedemall
- Hagerstown,Md,USA
My sportline is topping out way to fast and I'd like a higher top speed out of it. The car is an awd with single speed,currently the gearing is 40T spur,24T pinion. The motor is a G260. In order to accomplish what I want to do, should I go up on the pinion,or go up on the spur gear? Also,there seems to be no way to adjust the space between the two gears if you were to go up,or down for gearing. Am I stuck with the gearing that I have? I am used to running electric cars and being able to move the motor back and fourth to compensate for gearing changes. This will be my first time attempting something like this on a car of this type. Being a noob to 1/5 I apologise beforehand if my questions make no sense. Hopefully someone can help or give advice.
Thanks!
Thanks!
