need a little help please!
tizdaz
Sunny Northwest!
had a good day till the end when my servo (rhino digi 4) packed up after 7 years! when i got home i dismantled the servo to find this:
ive managed to find the 5755 gear set which uses exactly same as the rhino:
http://www.kingslynnmodelshop.co.uk/p3820/Hitec_HS-5755MG_Metal_Gear_Set_-_Instock/product_info.html
but i also need the rubber seal that seals the top & bottom halves of the servo when put it back together (you can see the rubber seal in the 1st pic going all around the top edge), again its exactly the same as a hitec 5755 but i don't know what the part number for this seal is, anyone have any idea?
cheers :)
I would contact Steve Webb models http://www.servoshop.co.uk/
They should be able to sort you out with parts & advice & you can nip over to collect as local to you. If you have had a better price elsewhere they will probably price match as well if you ask.
