Need advise from experience.
Timduli
kvassåsveien 22, 4380 hauge i dalane
Hey guys.
I recently bought a new engine for one of my bajas.
http://www.largescalerc.com/285ccraceportedchromecymotorcomplete-1-1.aspx is the one i bought this time.
And i was wondering, wich pipe would go good with this one?
i currently have http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.5995/.f and
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.6344/.f
First one is ok, but not that impressive, altho it is good.
Second one is pretty awesome from the start "low end power" but i do not like this at all when im in the sand or whatever and want some speed, as you do not get any power in the end, compered to the first pipe i linked.
Tho what im after is something that is ok at low end and middle, tho powerful in the end at high rpm.
Anyone here who has tryed this engine, and found a pipe that went good with it?
Im currently still at 17-57 gears, but planning on going for 18..
Tim,-
Your best bet will be to use a Side pipe, i've had the Victory Pro Silenced pipe which was very good and now run in between the Fluid RC and the BZM side pipes, think both are very good pipes..
A quick vid with the BZM pipe, my clutch was virtually stripped so it could have been better with a bit more meat on the clutch..
[ame="http://youtu.be/deD2UT-93ds"]http://youtu.be/deD2UT-93ds[/ame]
I have tried most pipes and I think the DDM Dominator comes out on top if you want a good all rounder.
I use a GBE end bleed and this is the pipe thats best suited to my needs .
J
Nothing beats a vrc pro pipe on the big end, NOTHING. If so please prove it. The pro pipe pushed my OBR FM30.5 5B over 17,000 rpm while pushing 34P-40Spur gearing. 85+mph
