need bearings for servo saver post
You must be trying to replace those brass bushings. It's an oddball size. Avid doesn't have them. Try some white lithium grease on the shaft, that should smooth things out a little.
I have found them in 6x10x3 mm so i will just turn the post down to fit Thank you if you need bearings readyrollers.com have that size there just out of stock at this time 10.00 bucks for 10 bearings :D
