need help with belt drive v3
contryboy MT
Junior Member
hello i have a mt v3 and i received my belt drive. I also bought the conversion kit from rc pitstop they have been great just one small ? where the bell crank comes through the housing which is aluminium it pushes the outer bering out like my bearing is to small for the shaft hears the bearing number it is pushing out 608zz can anyone help me please thanks
i think i figured it out need to know if the v1 v2 mount is different from v3 i think that is the differnce looks don't think where the bearing rides is deep enough to me can someone with a v1 v2 gear mount think thats what its called ck for me
The gear plates are the same. You might want to try and clean up the shaft with some fine sand paper or some steel wool and see if that helps.
actually the gear mounts are different the one i have with the truck is smaller were the bell crank goes through it i order the 050004 everyone was out of stock luckly red cat has them in stock now i recived it yesterday and everything works now think it only makes since i had the short bellcrank and im trying to put the long bellcrank in yea its a shorter housing
