Phill2
That's the only manual I could find too.Deluge said:You can either pull the engine out, or you can remove the whole rear diff housing. Removing the diff housing would be the easiest way. I believe it's just six screws from the bottom of the chassis, and four from the rear top plate and it'll slide right out.Here's the link to the manual:
Dunerunner Manual
The info you need is on page 10.
Does anyone know where to find the 4WD one or if t even exists?
Thanks
Phill
