Need help
Iwar0214
New Member
I bought a chimera gas two days ago today while running it I lost all control. I figured my battery died. I charged the battery and started the check list before I fired it up. The steering will not work now. When I unhooked the battery I noticed all the wires was loose from the receiver. I hooked everything back up and still no steering. I tried to rebind it but still no luck.
No. I get zero response. I tired new battery’s in the transmitter and made sure the other battery was fully charged
insert bind plug. turn on receiver. hold bind button on transmitter, turn on transmitter. just making sure that what you are doing
You may need to stand in a different position sometimes to close wont work try pointing your radio away from the receiver and make sure there are metal objects in the way, I fly RC planes and we nee to be a few feet away when we bind otherwise it doesn't always work
