no i don't race i wish(don't have the money or a good truck that will travel that far).
i have a fue?
1= can i remove my tires from my rims?? if so how?
yes, but its a pain in the neck and regluing them is tough. the aggrivation is not really worth it
2= do you balance your tires? if so how?
no. if your tire has an ueven wobble it is mostl likly a bent rim
3=would i want sticky tires for the rear? what should i use for the front?
all depends on temp and surface. with the pmt's, the higher the number the harder the compound. the rear tires wear out the fastest, so a harder compound will be better. for good wear and traction i would say #20's all the way around when its over 100*. as it gets cooler go with a softer compound.
this tire thing is new to me and this being a 2wheel drive just don't no what compound for front or rear. is there a good site that goes throw tire selection?
go to rcuniverse.com, they have a large scale section.
thanks very much for all your help.
i love the car but the stock tires SUCK. i even modded the engine and went throw the hole car the suspension was very stiff the stearing did not work becouse it was so stiff. now all is good, im just trying to get the front brakes to work right
