Great Sira,did you buy the 2.0? If so how was it when you took it out?
J.
Yeah... I got it about 1 month ago from Dan...
It's help up nice even though I did smacked a pole head on at about 20mph and bent the front upper plate... (my fault) I just banged it back into shape.
I did a short brake in... and then I just hammered it... so far the engine has responded very well.
I've been doing mostly Dirt track jumps, just to find what the weak points are and so far..
I bent the front upper plate... I ordered an HD one from DDM (not here yet)
Had 1 rear shock shaft pull out(maybe some limiting straps might help)... I ordered 2 HPI replacements shock shafts $16 (just got in today)... I also stipped a rear Wheel, but it was my fault for running it loose for a full day! ( I made a mental note to tighten it before the start of the day... I just forgot to read my mental note!)
I have upgraded a lot of parts just to take my hard bashing but I have not installed them yet... I will tomorrow when the rest of my parts come in. I haven't had the need to install them yet... I just want to be prepared!
I'm in the process to take appart and add 15k oil to the diff.... for my driving style (dirt mostly).
I also got street tires and sand tires... just to cover my options
Heres a link to my 1st thread on the 2.0 and it's progress...
https://www.largescaleforums.com/showthread.php?t=7430
Tomorrow I will installing:
HD upper plate
Hd tranny plate
HPI steering arms (so I can use the sealed bearing in the fasteddy kit)
Installing all new bearings kit (mostly for the possible missing bearing mod)
Fixing my shock shaft pull out.
If I were you the main upgrade I would consider is installing all the OuterWear Pre-filters and check those shocks for fluids...thats it!
At the moment it's very dirty ... full of clay dust from the track... I also put on a fully painted HPI Baja Body
h34r:
