New car to the collection
reckone said:
Just picked up a Rampage Rally. Currently running a stroked 29cc fulie, pipe and boost bottle. I plan to make a roll cage for it and set it up as a drift car for the most part. I would like to get a front brake setup if anyone knows what will fit. Pretty sure the FG wheels bolt right on to it also.DSC03569.webp
What the heck is the boost bottle?
strodedawg said:
need to make an electric one for some road racing :)
i made mine brushless and it its the craziest thing i have ever driven ..if you manage to get one and convert it to brushless prepare for your tire bills to go through the roof.
Deluge said:
It's a waste of money.
Pretty much. Came with the car...
Where do you get your tires form? I am looking to pick up some tires and a different set of wheels for mine.
Picked up a TT roll cage and made some custom mounts for it. Looks a lot better! cage fits perfect under the body. Also mounted the boost bottle to the cage, not that it matters... I need to pick up a alloy rear body mount. Mines sags due to the support not being there. The pipe gets right in the way of the support, so it doesn't fit now.
biggiecamp said:
May have to check into the rollcage myself. There's too much flex in the chassis. What mods did you make to fit pipe on the rallye? How's it perform?
As for tires, check with LSRC or FGsupply
Sent from da lower level iPhone using wanna Tapdatshit
Pipe was on there when bought. Looks like they only thing needed is to remove the rear diffuser/ body mount support. Engine is built up so I have nothing to really compare the pipe with. It does seem to flow nice. The cage deff makes the chassis ridged. Even tho the cage is oem plastic, I can carry it by the cage with no problem.
Also got a set of FG brakes on the way for the front.
you might want to put the shroud back on your engine because your not going to get much airflow with the body on it.
Never had one. What you see in the first few pics is exactly how I got it.
