new engine wont start question
shayno
I have a new obr 30.5 prostock. I got everything all set up and fired it up on the first pull. It idled for ten minutes and then died. Now I cant get it to start. Im assuming its flooded. What im wondering is what line goes to where on the carburetor? Top to clump or bottom? And when its idling what temp should the engine be?
clump gos the the bottom of the carb.
got it thanks. And the coil inside the spark plug wire was to loose to get a good spark. I tighted the coil up by squeezing with some needle nose.
I got it running good, ran the 15 minute idle, and then the full tank just barely moving it in circles and figure 8's. Tomorrow I will run the next two tanks at medium idle.
