New Futaba 1/5 Scale Servo. FUTABA BLS373SV
Whoduh
Fairfax, VA
FUTABA BLS373SV
Page is translated from German
FEATURES
  • · Powerful S.BUS2 digital servo with metal gearbox
  • · Hi-Voltage
  • · Brushless motor
  • · Ball bearing
  • · Robust aluminum housing
  • · High resolution
  • · High repeat accuracy
  • · Low-wear potentiometer
  • · Water protected
TECHNICAL SPECIFICATIONS
· Operating voltage: 4.8V ... 7.4V
· Operating speed 60 ° (7.4 / 6.0V): 0.14 / 0.11 s
· Actuating torque (7.4 / 6.0 V): 31.0 / 37.0 kgcm
· Dimensions: 40.5 x 21.0 x 38.4 mm
· Weight: 84 g
DESCRIPTION
Latest 1/5 car HV servo. Supports the SR mode of the T7PX transmitter. Programmable and compatible with S.Bus and S.Bus2 systems. Can be connected to a PC and programmed with the separately available CIU-2 / -3 USB adapter. The transmission end wheel is now made of stainless steel. The toothing to the servo lever is made of stainless steel, which means a significant increase in the load capacity in the direction of force.
Source: http://www.ripmax.de/svo-hv-brushlss-s-bus2-0-11s-37-0kg.html
Weight and size put it just larger than standard. Very interesting!
$313 37kg/cm, no thanks! Savox SB-2290 has 49kg/cm for $159 and its lighter!
