New guy w/a couple questions
proflow
Buckley WA
Hey folks,
I'm a new owner of a King Motors T1000 w/2spd.
After a little break in & tuning this thing rips !
A couple of little bugs to work out yet though.
I put a metal pawl in the starter before the plastic one ever was used. Only thing is it doesn't always catch. Sometimes I have to let it snap back in for it to catch.
Any Ideas w/this one ?
OK, also the truck creeps forward even @ low idol. I actually have to apply brake to keep it still.
Last but not least: Anyone know where to start on the two speed adjustment screws from bottom out ? Factory settings ?
Thanks in advance--Proflow
Hi there and welcome to large scale ! :)
Had the same problem with my alloy starter ring (i assume this is what you are referring) try sanding it down somewhat where it looks rough. Fixed it for me.
Have you turned out the idle screw enough? It should not creep when idling. This will probably result in a lot of unnecessary wear on your clutch. If you cant turn out the idle screw any more it might be a good idea to invest in stiffer clutch springs.
Here is a post that covers the carburetor tuning with stock values for the needles.
https://www.largescaleforums.com/showthread.php?t=2761&highlight=tuning
Cheers
Sounds like your clutch is engaging early try changing the springs sometimes when they heat up they will falter under load.
I'll try cleaning up the casting on the starter ring. Thanks for the tip.
Ive got the low & hi speed needles tuned like a swiss watch. So I must need to pull the clutch apart & see whats up. Weird just cause its new. Supposed to be a 8,000 rpm clutch.
Any ideas on factory settings on the 2 spd ?
Thanks---Proflow
If it's a new clutch spring and I'm assuming it is not idling at 8000rpm, then yeah take it apart and check it out, somethings up.
