The Zenoah G62PU engine is a 62cc performance machine. Includes Walbro HDA-48 high-performance carburetor, Champion RCJ-7Y spark plug, and canister muffler. Sold as shown.
Note: This engine was supplied specifically from Zenoah without ignition coil, flywheel, etc, so it could be used in R/C car applications (specifically, the KRD/Skopod conversion kit to allow this engine to fit into an HPI Baja 5b). In current form, this engine is not complete to be used in an R/C airplane.
Engine Stats: Displacement: 62cc (47.5mm bore, 35mm stroke). Power: 5.4HP @9,500 RPM. Torque: 3.04 ft/lbs @7,500 RPM. Compression Ratio: 8.2:1. Fuel: 87 octane or higher mixed 25:1 with 2-stroke oil.
some more info
Specifications Type 2 cycle piston valve type gasoline engine
Cooling System Air Cooled
Bore x Stroke (mm) 1-47.5 x 35
Displacement (cc) 62
Maximum Output Net ps (kw) 5.0 (3.68)
Gross ps (kw) 5.40 (4.00)
Maximum Torque Net (kg-m ) 0.41
Gross (kg-m ) 0.43
Rotation Direction Counter-crockwise(viewed from PTO shaft)
Fuel Pre-mixed Fuel, 25 (Gasoline) : 1
High grade 2 cycle engine oil)
Lubrication Oil High-grade 2 cycle engine oil
Carburetor Diaphragm, butterfly valve type
Ignition CDI
Spark Plug RCJ-7Y
Overall Dimention
Length (mm) 163
Width (mm) 222
Height (mm) 197
Dry Weight (kg) 2.35
heres what i found on the engine so far
