new km 3.0 not responding
FransR
New Member
Hello,
I just received my King motor baja 3.0 29cc RTR. The car however does not react on the transmitter. The batteries are loaded. Any thoughts?
Thanks.:D
Welcome!
Can you hear the servos when you turn the car electronics on? Does the radio have power? If yes to both, you might have to rebind the transmitter to receiver. There should have been a small binding plug included with the kit for this purpose.
If you turn on the car and nothing happens, pop the top off the radio box and double check all the connections.
guess sometimes the radios can be shipped and it not have or lose its bind, mine was fine when it arrived. just make sure BOTH Tx and Rx batteries are charged up or replaced with new ones, mainly the radio, the recievers should be rechargeable in the radio box via a plug cover.
radio on first, then truck, if nothing then, try rebind as mentioned above, if nothing stillcontact place you got truck from for further instructions, it might be a faulty radio system if all the above mentioned things are good and still no response.
problem solved
Thanks for your advice. The problem is solved. The manual said "Our products are well matched in our factory" but after being matched the car did respond.
Today i made my first tour with the car, and i must say it really drives like hell. The car responds very good on throttle, stearing and brake. I really enjoi it.
Thanks,
Frans
lol a 1 in a million deal where radio lost bind to Rx, i guess it happens, lol glad its going ok now, now get out there and tear the heck outta some ground!!!!!
Technically it will fit in both, but right now the ONB twin is designed to fit inside the team chase cage which is designed for the 5T.
