New KM build, PICS
Gas>Nitro
Seattle Washington
Started with a KSRC-002 29cc dom pipe etc.
Electronics:
Futaba 3 channel 2.4ghz
Hitec HS-XXX-MG servos, throttle and steering
Drive train/engine/suspension:
Outerwears all around
NKG plug
DDM enclosed clutch
HPI alloy diff case
Dark Soul dog bones w/ Hostile boots
Full Force V2 fuel tank mod
Hostile MX Super Hard rears with HPI dirt buster fronts
TR pull start
TR front suspension tower
Maintenance:
Yamalube fork oil 20w in shocks
Valvoline multipurpose grease in tranny
Fast Eddy 10k in diff
Yet to come:
Turtle Racing rear shock support
Eventually custom wheels
Thanks guys!
looks good bud, any other future upgrades you plan on?
Yea there's a freaking laundry list of things haha I have it fairly planned out based on when my current stuff breaks or Christmas/Bday haha.
1. TR rear shock tower next
2. RPM A-arms in pairs of two, so If I break a front A-arm Im just gonna replace the left and right at the same time.
3. When these tires are spent I'll probably get the "Mercenary" wheels off DDM with another set of Hostiles cause these tires are amazing
4. I'd like an alloy tranny case or the TR "quick diff" as well
5. If this motor ever craps out I'll spring for a Zen to.
But so far this little KM 29cc has ran pretty well only real engine mods are the NGK plug and Full Force tank fittings and lines. I had to do a little custom work to get the enclosed clutch housing to fit but it works great now. Still breaking it in on the first tank running around 22:1 or so cause I mixed a little heavy. But no complaints so far!
Thanks guys!
nice, the whole back end on baja is TR except for teh clutch system which i hadn't planned on but after not being able to find a vented clutch bell for teh stock system i have to either go with a tr or a vp clutch setup. the vp setup doesn't really offer a way to adjust an elcon or lauterbacher clutch without some disassembly so i will end up with a tr setup.
i am down to only needing the clutch setup, and some bling now (lighting and a couple other items) to get my baja where i want it but getting it running again requires a new carb because my carb body failed (plug inside of carb body fell out and dis internal carb body damage).
look forward to seeing future pics as your baja progresses :D
What spark plug do you use? I fouled a NGK CMR7H pretty quickly, wondered if people used anything different.
i have teh one that came with my baja in the fuelie 26s (CMR7H), of course i haven't done a whole lot of running either (genuine baja 5Bss by the way ;) ).
Yea I could have bought a HPI or at least I'm pretty close to it now in aftermarkets. But If I had done that I wouldnt have all the hop ups I have on it now.
Get the Exhaust mod done as soon as you can .It'll save the heartache later.
J.
Yea I'm gonna do that soon
