Hi all,
I am back into RC after about 10 years away and grabbed a 5T 2.0 as my electrics don't give the same fun as my nitros used too. I am just having some trouble getting it tuned. I am about through a gallon of gas but keep fouling plugs... Can someone point me to a good video on tuning these carbs?
I thought I had it dialed in on the last run I did as it didn't bog or seem flat up top from being lean but when I went to start it the next day I had fouled another plug... This is probably my 5th one so far. I did lean it a little just to see how it would act on this plug that just died and it clearly was to lean so I put it back to the settings I had prior. I am making small 1 Hr adjustments on the needles when tuning. It seems like the tune is good and I would leave it if it weren't for the fact I am ruining plugs every tank. Seems to run fine but then when I go to start it I can't get it to fire as soon as I drop in a new plug it starts first couple pulls.
I am using Motul 800 at 25:1 with 91 OCT No Eth fuel. I can't get any higher here.
Thanks for any help!
