new oddified big disc kit
renbar
kirby cross essex
these must be the largest disc brakes ever fitted to a marder based car this conversion is made by ian oddie and will fit fg,contrast,harm ect he also does these for hpi Baja's losi's
I doubt you will need any more braking than this setup will give,, huge 85mm fibre disc's teamed with hydros the kit includes spacers fibre disc's bolts pads ect this kit is meant to only work with the larger off road wheels but im using hpi wheels on mine and it works ive also fitted a fg lorry slick on the bug which also works and spins free honestly they look crazy you can barely see through the fg spokes its just full of disc would look bonkers on a fg lorry
ive yet to try mine but I can barely turn the wheels with the brakes on im using contrast calipers on the bug I had to run these from my layshaft hydro due to no space for a extra master cylinder but this seems to work ok
to be honest mate the front spends most of the time in the air,, but to answer your question its only really the rears that seem to get covered never been a problem on the front
