New Rampage MT 2013
surun211
Junior Member
Well everyone my MT just came in and I figure I'd put some pics, so everyone can put their input on new updates, things that only previous MT owners can find.
ALL Comments are welcomed!!!
More Pics, MT V3 puschased feb 2013
/monthly_2013_02/583c606705e68_DSM-2CTransmitterSettingknobs_Converted.jpg.be85fae9d2047ca6f93fb8a52496e76d.jpg
/monthly_2013_02/583c606708ae2_DSM-2CTransmitter_Converted.jpg.f71908348fa50c03e6c6de653070c0da.jpg
/monthly_2013_02/583c606709e59_Frontunderside_Converted.jpg.6e1dff935a920640235bd49bda9bab55.jpg
/monthly_2013_02/583c60670b279_MetalSteeringServos_Converted.jpg.235b49333a0a62d62f8ea2a3929be4d9.jpg
/monthly_2013_02/583c60670c66b_RampageMTV3Jan2013_Converted.jpg.a19f9d206fd80539fa78afe143cc81ca.jpg
Here you go Fellas, more pics
/monthly_2013_02/583c60670da4a_RearDiff_Converted.jpg.11dbac0c4d866613fa8b9d25f0443e7c.jpg
/monthly_2013_02/583c60670ef19_Rearunderside_Converted.jpg.5a09ea18e09ac6fed44c58297e62bf9c.jpg
/monthly_2013_02/583c606710426_WheelAxles(1)_Converted.jpg.8eef5e7f94786e7992863f93dc54eabc.jpg
/monthly_2013_02/583c6067116ca_SteeringServosampTh-BrkServo_Converted.jpg.99d62b9a4dd646ea24333774832681f5.jpg
Re: New Rampage MT 2013
Thanks...fun playing find the difference...
The one thing I see is in the first pic...the brake cam looks to be shorter....there used to be a piece of fuel tube as a spacer from the top of the brass grommet to the bottom of the lever....
Also the lever at rest seems to be at a different place....
I bring this up because I seem to have always had problems getting the brakes set just right so the outer disk doesn't slip off the hub. (basically when they are 'loose' going full throttle position) during my recent teardown I had to buy a new brake set (loose grub screw in the cam caused me to lose my lever...then pass went really wonky and stripped the outer one) and the new one is same as I had before.
So does Anyone know if they redesigned the cam?
The photo is stretched, but it looks the same as mine.
They are not the best servo, but not that bad either. They are metal geared and with a good EPA set you can get some run time out of them.
