New Redcat MT not running
kh0de91
Hi,
New on gas RC.... need help regarding my newly arrived Redcat MT, everything was ok all the way to half tank suddenly the truck stop while its engine was still on, when I press gas throttle but its only engine acceleration was running but not moving forward, both steering servo was ok its turning on both side, tx radio system was ok,,throttle-gas servo was fine, any idea are really much appreciated. :confused: :confused:
many thanks on replying
When you Rev the engine is it moving any of the gears or drive shafts? If it is then you probably had one or more of the set screws in the drive train come loose the factory isn't known for properly threadlocking these trucks parts.
I manually push on reversed all the gears and drive shaft and it has moving...
I had it happen to me I was going crazy but the two Allen screws had came loose from the A gear use blue locktight of that the problem
designed2survive said:
First gear attached to the clutch bell (engine).
Finally got it.. the 2 small allen screw has loose and lock tight it..
thanks for the help guys, really appreciated !!!!
