phatdad
These shafts are a 4.8mm dia heat treated stainless steel shaft. Now you will be able to better tune your redcats suspension using the HPI hyper adjust disk. Also no more c-clips. Kits will come with every thing you see here except you will have to install your stock lower shaft ball end(not supplied). Rampage hopups should have these kits in stock in the next couple weeks. New shock towers coming soon.
