Mike1970
I've had some new servo mounts made so you can use a Tonegowa in an FG Leopard 2 competition.
Damn Mike,
You're a racer so you 'have to' take care of these things but are you certain that steering rod doesn't catch the upright mount - looks very close? !!
Nice job 'though.
Regret selling my ventilated Tonigawa I suppose, 'though a Rhino is more than enough for what I need for on-road.
Nice looking mounts. What is the speed of that servo?
5B I guess is the buggy? You're probably right that it won't fit due to the size and getting in the way of the body work but wouldn't in be possible in the truck version?
No the truck is basically the same as the buggy just has extensions on the side but the chassis, radio box and so on are all the same. Do not think it will work in them either.
i saw ian a few weeks ago, i asked him to oddyfy my tonegawa, he said it makes it exactly twice as fast, i think its normally .20 at 60 deg, so twice as fast, i have a 7.2v and 8.4v,which the tonegawa can be run,so even quicker, thats fast enough for me, i still haven't installed mine,its brand new,This is the standard details, once the servo is "oddified" it's far faster and uber reliable. When I get hold of Ian, I'll ask him for the figures. I used to use one on my on road race truck, it was that good, I bolted the servo saver up and never broke anything.
The data below show calculated figures, not measured one.
Constant torque ≒ Stall torque x 1/6
Example:
10.5 N・m(107.7kg-cm) in stall torque at Input Voltage 8.4V
9.6 N・m(92.4kg-cm) in stall torque at Input Voltage 7.2V
7.5 N・m(77.0kg-cm) in stall torque at Input Voltage 6.0V
6.0 N・m(61.6kg-cm) in stall torque at Input Voltage 4.8V
The operating speed and power vary with input voltage.
Revolution Speed of horn at 60deg in input voltage 6.0V is 0.3/sec
PS050 may be mounted on over 3 to 4 meters class wingspan plane.
Dimensions L100mm W44mm H93mm Weight 290gr
The output shaft is supported by two large-diameter ball bearing.
JR connector is used. This can be also connected to FUTABA and other receiver.
you can run the tone off its own battery supply,a small hump back is perfect!Hi Mike, as a racer, is the Tonegawa going to be pushing your battery capacity to the limit, bearing in mind the long race times of Large Scale - have you tried an 'endurance test' to see how the battery holds up?
Do you have spare batteries lined up for such circumstances during races?
Just a thought,
As it's under the bigger shell, you could move things round like the radio box, throttle/brake servo and front brake servo.
